Old 01-17-2010, 05:06 PM
super_man_736 super_man_736 is offline
1996 wheel problem
When i push on my brakes the wheel rubs on the splash guard i think its a alignment problem.How much does an alignment usually cost.
Old 01-17-2010, 06:35 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1996 wheel problem
If it's rubbing, then there just about has to be something loose. Most likely a lower control arm bushing. Check that out, then have the alignment checked. We charge 1/2 hour to check the alignment, and 1 hour and up to adjust it, depending on what needs done and the vehicle. Simple toe/camber on a Cavalier, probably 1 hour unless it's really rusty and needs to be heated to break it loose. Camber involves removing the struts and elongating the holes, so quite a bit more there.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
