Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 01-16-2010, 08:16 PM
jackmcc jackmcc is offline
malibu heater problem
i changed the thermostat on my 99 malibu and drove it for a while and it done good for a while but then it started overheating again and the heater will not heat now does any body know what my problem might be
Old 01-16-2010, 10:36 PM
danielsatur danielsatur is offline
Re: malibu heater problem
Need to do a coolant bleed procedure, because of the air pockets in your system.
Old 01-18-2010, 06:07 PM
we bled the air out and it still overheated but i am going to do it again
Old 01-19-2010, 11:38 PM
jyount jyount is offline
get an infared temp gun and check it, when sitting in traffic my gauge shows a couple hash marks higher, but when I temp gunned it it is only about 10* more than it usually is, so long story short very little change over the norm and my gauge interprets it as a big change, this IS NOT normal, I AM NOT saying this IS your problem, just something to check. If you really are overheating by all means shut it down when the gauge says so...
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
