Old 01-16-2010, 01:23 PM
super_man_736 super_man_736 is offline
1996 front brakes
The brakes on my cavalier make grinding noise when the pedal is almost to the floor when i stop i just replaced the rotor and the pads
Old 01-16-2010, 04:02 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1996 front brakes
Pull the rear apart and make sure they're not the cause of the noise.
Also, if you mean you replaced the pads/rotors recently, not as an attempt to fix the noise, the fronts could be worn out again. You have to remove the rubber bushing from around the slide pins and remove all the rust and then grease up the bushings on both sides before reinstalling. If you don't do that, the outside pad will never fully release and wear out quickly.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
