Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 01-15-2010, 08:26 PM
smoking70camaro smoking70camaro is offline
99 dogdge 2.7 timing help
i have a 99 dodge intrepid with the 2.7 and im try to set the secondary timing chains i got the haynes manual but it dont help much the problem im haveing is the cam on the passanger side only has 2 dots on it to line up the secondary timing chains and the driver side has 2 dots and to triangle on it i dont know wich one to use and iv try both and lined it up with makes on the chain but the primary chain wont line up if the the secondary timing chains are at 12 o'clock but if i turn the cam the primary chain lines up but the secondary timing chains marks are not at 12 o'clock aney more what ame i doing rong can some help me at [email protected] with some pic or some thing thanks much
Old 01-15-2010, 10:53 PM
hundahunta hundahunta is offline
Re: 99 dogdge 2.7 timing help
the chain on the cams need to bet set first...gold link to dot etc....after that set the main chain...the cam chains will not be at 12 clock
Old 01-16-2010, 11:07 AM
thank you varry much
