Old 01-15-2010, 03:43 PM
paulf717 paulf717 is offline
96 Dodge Tranny problems???
Just looked to see were all the fluid came out under the van. Noticed that the case in the back of the trans pan has a huge whole in it.. Looks like it came from the inside outwards. Also there is a piece of a gear floating around inside. Doesn't look like it is going to be fixable. Any ideas.. BUMMIN
Old 01-15-2010, 06:53 PM
tempfixit tempfixit is offline
Re: 96 Dodge Tranny problems???
Sounds like the pin on the sider gearshas worn a hole in the housing.
Old 01-16-2010, 01:37 AM
trannyman52 trannyman52 is offline
Differential assy blown,,,cross pin that retains spyder gears pushes out machining the case {rips a hole} thus blowing atf out the bell hsg,,,must have got-er stuck!!!!!...very common on these
Old 01-21-2010, 09:34 PM
Is the van all done....
Old 01-21-2010, 09:44 PM
Not sure what you mean by all done. The transmission will need to be replaced, existing one cannot be repaired.
