89 park ave stumbles and dies
Hi, I have an 89 Park ave 3.8 with 92k miles. It starts fine then after a about 5 mins it stumbles and dies. If i give it gas when i first start it its ok, but that 5 min mark it hesitates and stops running. I changed the plugs and wires with no luck. It does start back up but keeps shutting off. Any help would be greatly appreciated. Thanks.
Re: 89 park ave stumbles and dies
This sounds fuel related, so that is a good place to start. When is the last time you had the fuel filter changed? Have you checked the fuel pressure with engine running?
Knowledge can be communicated, but not wisdom! ![]() ![]() |
I agree with Bo.. First thing is to get the fuel pressure checked, see if the pressure drops suddenly and causes the stall..
as well the pressure should be 37-41 Psi for the Vin C 3800.. |
While i was changing the fuel filter i noticed a rubber hose had rotted for what looks like a fuel vapor line that runs next to the metal fuel line. I fixed that and the cars seems to be running better. Could that have made a diff? Thanks
Yes a huge difference.... These cars use a MAF system, if there is a Vac leak anywhere behind the MAF you can have all kinds of driveability issues..
If it was a rotted line you found then most likely that was your problem.. |
