Old 01-15-2010, 09:40 AM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Exclamation Help
i have a 2005 trailblazer 4500 the gas needle only markes E does anyone know what it might be. Sometimes it moves to a 1/4 then it comes back down even when i fill a full tank
opcorn:
Old 01-15-2010, 09:42 AM
maxwedge maxwedge is offline
A990 racer
Re: Help
More than likely the tank unit is bad, a scan with a full function bi directional scanner can check this.
Old 01-15-2010, 10:12 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Help
It may also be a defective stepper motor in the instrument cluster (the same model was used for all the gauge needles). Many GM vehicles in the 2002-2005 span have had problems with false gauge readings, especially the TrailBlazer/Envoy models. I've had my IP replaced once and repaired again. Apparently the original motor design was faulty, eventually causing to go haywire...RPMs at 7,000 at a standstill, voltage at 19V, fuel gauge at 3/4 after 300 miles, etc.
From your symptoms (steady reading, moves slightly but consistently with tank fill) I'd be inclined to agree with maxwedge, but there is another viable possibility. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
