Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 01-15-2010, 07:12 AM
noble527 noble527 is offline
crank pulley 2.3 1989
replacing the timing belt on a 1989 ford ranger, was pulling the pulley off with the proper puller and the pulley casting assembly broke in half, and the other half is still on the crank. Any ideas.
Old 01-15-2010, 06:05 PM
rhandwor rhandwor is offline
Re: crank pulley 2.3 1989
http://www.autopart.com/tools/toolsmain/tool/T_8065.htm
You tighten around the piece behind the broken pieces. The two holes are threaded use the puller you was using. Maybe a larger puller look for a loaner at the parts stores.
