Old 01-15-2010, 12:06 AM
jeremyjjj jeremyjjj is offline
91 chevy open diff swap to posi lock
I have a 91 chevy with a open diff i was wondering how do you tell which rear ends can you swap right in that is a posi lock. Like which trucks would be a donor truck.
Old 01-15-2010, 09:21 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 91 chevy open diff swap to posi lock
There is usually a screw-mounted tag attached to the housing to indicate this. If you are looking at donor trucks and not just rear axles, you can look for the G80 option on the RPO label in the glovebox.
Also make sure you match up the gear ratio otherwise you're speedo/odo will be off. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-15-2010, 09:35 AM
jdmccright's Avatar
The RustBuster
If you're just looking at the axle itself, there should be a metal tag attached to the housing with a screw identifying it as having a posi diff.
If you're looking at axles still installed on a truck, check the RPO sticker in the glovebox for the G80 option. This isn't 100% though since some owner's could swap them out, but usually they'll put a posi diff in rather than take one out for an open diff.
Acid test is to inspect it with the cover off, obviously. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 01-16-2010, 11:59 AM
twingl27 twingl27 is offline
I have a 2000 1500, the sales paper says it is a C10 but the cab has a Silverado emblem on it. How do I figure out if I have an 8.5 or 8.6 10 bolt rear? Spider gears are trashed and need this info to replace. Any help would be greatly appreciated.
Old 01-16-2010, 05:34 PM
777stickman 777stickman is offline
The C10 is simply a 2WD 1/2 ton Truck. The "Silverado" emblem is just a truck line with more options than standard.
For the rear end, take the VIN to the dealer or a salvage yard. They may be able to tell what you have. Also as posted above look for the RPO code in the glove box or the tag on the differential.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
