Old 01-14-2010, 11:14 PM
cavalieronyc cavalieronyc is offline
pcm/bcm reflash removal
how do i remove the pcm/bcm i tried touching + - battery terminals but does help
Old 01-16-2010, 04:07 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: pcm/bcm reflash removal
Do you mean clearing codes? You have to do that with a scan tool. Most code readers will clear P0xxx codes, but for Cxxxx, Bxxxx, Uxxxx, or P1xxx you need a more advanced scan tool.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
