Old 01-14-2010, 10:39 PM
cavalieronyc cavalieronyc is offline
which delco radio is non rds
hi i took out my factory am/fm delco 2001 stereo and installed aftermarket stereo, but am tired of remove and replacing detachable face everyday and want a radio with a cd player that reads LOC on the clock from junkyard not LOCKED rds type since GM dealer wants $120 for tech 2 scanner reflash which ones should i get? the ones with the tiny clock screen? theftlock from sunfire grand am?
Old 01-16-2010, 04:17 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: which delco radio is non rds
A lot of salvaged factory radios are more than $120. You'll also have to solder in the connector from the car you get it out of. I'd go with an RDS radio... or just leave the face on your aftermarket one. If crime is that bad there, I think I'd just move
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
