Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 01-14-2010, 07:40 PM
larrys 97 larrys 97 is offline
tranny problem 4R70W
when i am driving my 96 mustang 3.8 with automatic[ 4r70w ] every once in a while it feels like a vibration coming from the tranny i think. it lasts a couple seconds,but it may do it once or more, it varys. the tranny isnt slipping that i can tell.would it be a sensor on the tranny or the torque converter. please help me out . thanks larry
Old 01-19-2010, 07:29 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: tranny problem 4R70W
Sounds like it may be the Torque Converter Clutch (TCC) slipping. A way to test goes as follows:
When occurring, keep your right foot on the accelerator and with your left foot slightly press the brake pedal. This will cause the TCC to disengage. The RPMs should raise slightly, and if it is a TCC related issue, it should go away at this time. It will come back when you take your foot off the brake and the TCC once again engages. The TCC engages only in 3rd and 4th gears when the ATF is up to a certain temperature (above 80F, IIRC, which should take about 10-15 minutes of drive time in freezing temps).
Additionally, did you check the dipstick? Is the fluid bright red? Or is it discolored, possibly brown? Does it smell burnt? Is it filled to the proper level? Remember to check the level on a level surface with the ATF up to temperature (atleast 30 minutes of driving), and after you cycled through all gears (R,N,D,2, and back to Park).
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 01-21-2010, 01:05 PM
thanks for the information.i took it to the tranny shop and they flushed the tranny and put new filter and fluid in it,they also added a tube of stuff to stop the shudder.it worked.no more vibration.
