Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 01-14-2010, 07:13 PM
**__** **__** is offline
98 ABS light trouble
For a while now, the ABS light has been consistently on. First it started turning on after driving a short amount of time, then it started turning on and staying on after starting the car and waiting a minute or two, and now every time the car is started, the ABS light stays on right away. I noticed now that when I turning the ignition to "on", right away I can hear a quiet "click click" which results in the light staying on and not turning off (it does this all the time now). Is there a common problem to this issue or is it more specific?
Old 01-14-2010, 07:25 PM
danielsatur danielsatur is offline
Re: 98 ABS light trouble
1) Check your Brake fluid.
2) Do a Brake inspection.
3) Clean all four wheel speed sensors with brake cleaner.
Old 01-16-2010, 03:47 PM
LMP's Avatar
LMP LMP is offline
All of the above...Most common cause is related to wheel sensors, specially when front hub bearing go haywire..you would hear a humming sound. An advanced code reader will reveal the source of the ABS light being on, which wheel is the culprit, or ABS internals. Corroded contact at wheel sensor connectors happen to pop the light.
Low brake fluid would illuminate the red brake light, not ABS...but check level anyway.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
