Old 01-14-2010, 07:10 PM
CCMphysician CCMphysician is offline
Iso Heet Fuel Additive
What is your opinion on IsoHeet as a fuel additive? Does it really clog the fuel filter and can the isopropanol damage the seals by drying them out?
Thank you in advance,
CCM
Old 01-14-2010, 09:52 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Iso Heet Fuel Additive
My impression of IsoHeet is that it's an overpriced bottle of Isopropyl Alcohol (but not water-saturated rubbing alcohol). I suppose if you were using it in place of a tank full of gasoline you might run in to seal issues, but when diluted per the "treats x gallons" listing on the bottle you should not experience any problems.
-Rod
Old 01-14-2010, 10:48 PM
-Rod
Those are my thoughts as well. I see it as the non-azeotropic form of isopropanol with detergents added. My other question:
Do you think it could hurt the fuel filter?
Thank you,
CCM
Old 01-15-2010, 06:44 AM
shorod's Avatar
SHO No Mo
No, it will be so dilluted that it's not going to do anything to the paper fuel filter element, or even the nylon fuel filter sock in the tank on the fuel pump.
-Rod
Old 01-15-2010, 08:17 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
When it gets cold out, water can condense from the air inside the tank and settle at the bottom (it has a higher density and is immiscible). This can prevent starting, cause misfire, or stalling if there is enough accumulation. The main ingredient in Heet, isoproyl alcohol, is used to make any water in the tank miscible in the gasoline so that it can be sucked out by the fuel pump and expelled in the exhaust as combustion takes place...a little at a time so that it doesn't affect engine performance too much to set off warning lights. It is not designed as a fuel stabilizer or cleaner, only to remove built-up water.
As mentioned, the dilution ratio is low enough (when added to a full tank as directed) that the alcohol won't dry out seals. To be safe, don't add to a completely empty tank then fill up to provide good mixing. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-15-2010, 12:56 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
A bottle of meths will do the same job though, and cost a lot less
Tags
additive , ethanol , fuel , isoheet , isopropanol
