Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 01-14-2010, 04:24 PM
1badasschevy 1badasschevy is offline
Sunroof issues
I need a little help. My sunroof keeps stopping when I try to open it. It does the same things when I try to close it. How do I get to the switch?
Old 01-14-2010, 07:34 PM
consultIII consultIII is offline
Re: Sunroof issues
What year is your car?
I've had this happen and it turned out to be to much load on the sunroof motor from a seized track assembly. Lubed everything with penetrating fluid. Worked the track back and forth with help from a little hand pressure and it moved normally again.
Old 01-16-2010, 03:35 PM
Re: Sunroof issues
Its a 2004. Did you have any noise when the sunroof would stop? Mine is quiet, it just stops.
Old 01-16-2010, 05:05 PM
Re: Sunroof issues
was quiet...moved slower but noise abnormal noises.
if you still want to remove the switch; do you have the overhead console? Removal procedure is different.
Old 01-16-2010, 05:06 PM
Re: Sunroof issues
sorry ...moved slower but no abnormal noises
Old 01-16-2010, 08:15 PM
Re: Sunroof issues
Yes I have the overhead homelink console. I took the screws out of the console but had no luck
Old 01-16-2010, 08:33 PM
Re: Sunroof issues
-remove screw from console
-there are 2 retaining tabs on each side of the console; with a flat screw -driver push the tabs to the side and pull the console down from the headliner
Old 01-17-2010, 07:59 PM
Re: Sunroof issues
So ill be able to get to the switch from there? I remebered recently that I forgot to close the roof all the way in the summer and the headliner got pretty wet in that area. I want to check and see if the contacts are rusted out.
Old 01-17-2010, 08:13 PM
Re: Sunroof issues
yes. once the console is out, remove the switch from the console.
