Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-11-2003, 12:06 AM
xlosinghopex xlosinghopex is offline
Send a message via AIM to xlosinghopex
boosting with 93 octane
Anyone know how much boost a b16a can handle using 93 octane before detonation occurs?
Old 04-11-2003, 09:36 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
What compression ratio?
Old 04-12-2003, 02:29 PM
10.2:1
Old 04-12-2003, 02:31 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Originally posted by xlosinghopex
10.2:1
well 93 octane could probably handle up to 18psi maybe twenty.
But with your compresion ratio and if you have stock intenals you don't need detonation to rip the rods to sreds.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 04-12-2003, 02:52 PM
So my internals will give out before the fuel does? So then how much boost can a b16a3 with stock internals handle reliably?
Old 04-13-2003, 01:43 AM
Neutrino's Avatar
Yaya Master
yeah stock internals on most NA cars are very weak. safelly i'll say your car should run up to 10 psi on stock internals. To be on the safe side i'll say 6-8 psi. Also make sure you don't run lean that will cause detonation and extreme temperatures which will cause your engine to go BOOM
about the gas i'll say 93 octane will not detonate up to maybe 20 psi but that is with lowered compression so it depends from car to car. running lean will also lead to detonation. I know that the evo VIII runs 18 psi with 8.8:1 compresion use that as a benchmark if you want since is designed to run on pump gas but don't forget that many of thse cars have detonation sensort to retard the timing if detonation is about to occur. sensors wich you don't have
(\__/)
Old 04-13-2003, 04:20 PM
What would cause the mixture to run lean or rich? How can I avoid running lean?
Old 04-13-2003, 04:21 PM
Zippy's Avatar
Zippy Zippy is offline
Send a message via AIM to Zippy
Keep it around 7-8psi, safely.
Old 04-13-2003, 05:48 PM
Neutrino's Avatar
Yaya Master
rich mixtures are caused by too much gas in the mixtures they cause the gas mileage to be bad and maybe run a bit cooler.
lean is what is dangerous it causes the engine to heat up even up to the point of melting or can cause detonation. Either way its a quik way to blow up your engine.
the problem with turbo's on NA cars or increased boost on already turbo cars is that there is much more air comming in and the ECU cannot make up for it either because it software can do only so much or beacuse your fuel system just cannot deliver enogh fuel.
the probem around the ECU is to get a stand alone and program it yourself or get a piggyback ECU that will tell your ecu what to do. that is not enough if you plan to use high boost though in that case you need an upgraded fuel system like new injectors fuel rails and a fuel pump.
if you plan to use low boost like 6 psi i think your fuel system should be enough but i would recomend getting a piggyback.
if you plan high boost get a piggyback or stand alone with reinforecd bottom with new fuel system.
my question is how much money do you plan to spend? and how fast do you want your car to be?
(\__/)
Old 04-13-2003, 08:17 PM
We'll I'd like the spend the minimum for turboing a car so I was thinking about a custom setup buying parts from ebay. So to get a low end turbo setup with used parts I guess $1000-1500. Since I don't have the cash to make the car set any records I'm more realistically looking at low 14s. Also is there any way to know the stoic ratio other than a guage?
Old 04-13-2003, 08:30 PM
Neutrino's Avatar
Yaya Master
well sounds like you want a low boost low cost setup. then as i said what you need is a piggyback. but if you build it custom you'll need to do the tuning youself ta make sure you run a proper mixture.
to fund out how you run i still recomend having a gauge just to keep an eye during racing. But another way is to plug a computer in the piggyback that will tell you the mixture and that is how you will tune it.
(\__/)
