Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-14-2010, 02:04 AM
adktoyota adktoyota is offline
Exclamation 93' Camry shifting late (around 3000 RPM)
I have a 93 Camry (4 cylinder, A/T) with 185k and just the other day I noticed that the water pump was leaking and had it replaced today. Just the day before I started noticing that the car is shifting way late. Since i'm not an aggressive driver my gears normally switched around 2400 rpm and with ease (no jerking) this car before drove like a brand new car. Now I drive the thing and it revs up to 3000 rpm and stays there for a few seconds then shifts somewhat hard. I'm really torn over this because there was nothing wrong with the shifting until the water pump started going bad. IDK if its the transmission failing or the shift cable from the motor to the tranny. I also checked the fluids on the tranny dipstick and its perfect. Need help!
Old 01-14-2010, 09:50 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 93' Camry shifting late (around 3000 RPM)
Replace the engine coolant temperature sensor. It is most likely the problem.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 01-14-2010, 11:59 PM
Where would that sensor be located? On the radiator?
Old 01-15-2010, 12:13 AM
http://www.toyotanation.com/photos/d..._annotated.jpg Or is that the coolant sensor?
Old 01-15-2010, 11:51 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
^ The coolant sensor in adktoyota's picture is the correct sensor. It is the one under the green plastic connector. It is referred to as the engine coolant temperature sensor or the ECT sensor in Toyota's manuals. You can also check it for being in/out of range with a digital volt/ohmeter and the specs from any manual. There are Toyota factory service manuals stickied at the top of this forum that are available for free downloading. Download the generation 3 manual.
Mike
Old 01-16-2010, 01:05 AM
I just wanna say thank you and to brian as well my problem is fixed and I wouldn't have been able to do it without ya'll! If you lived in my home town I would buy you a beer
Old 01-16-2010, 10:07 AM
Brian R.'s Avatar
Resident Chemist
You're welcome. It's been a long time since I had a Lone Star...
Tags
problem , pump , shifting , transmission , water
