94 corolla
a now intermitant lack of power issue. 94 corolla 1.6 198k 2months ago car lost power at pedal wot throttle no response girlfriend got off freeway when this happened and putted it home. took around the block then lost all power. took to shop ignition timing off 20 something degrees. nothing broke leaking loose. everything checked ok other than timing. then today again same thing. barely starts. when it does barely any respose from pedal. so far everything checking ok. any pointers from any1 out there. im thinking distributor but dont wana shoot the money gun. thanks
Re: 94 corolla
When was the last one changed?
The problem with doing nothing is not knowing when you're finished. |
Re: 94 corolla
nothing broke. belt good. ignition timing off 26 after tdc distributor maxed cant change any more way i need to. base timing good.
Re: 94 corolla
Check that the ignition coil isn't bad or going bad, then the igniter. Doesn't sound like the answer, but the symptoms do indicate a poor spark.
Other ideas are stuck IAC valve, engine coolant temp sensor, and stuck EGR valve. Only the EGR is expensive if it can't be cleaned. Good luck!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
