Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 01-13-2010, 05:22 PM
jmartindba jmartindba is offline
01 Monte Carlo A/C Clutch r/r
Anyone ever replace the A/C clutch assembly on an 01 Monte? Do you need a special puller to get it on/off? I have a friend that needs it done and I am going to help him.
Jeff
Old 01-28-2010, 05:29 PM
j cAT j cAT is offline
Re: 01 Monte Carlo A/C Clutch r/r
Jeff
yes this can be done ,,,,problem is you need specialized tools...compressor needs to be removed,,,usually the compressor pulley bearing seizes...best get a scrap yard replacement , rather buying a new compressor...many have had good results...
this is not the job for a part time back yard mechanic...
however the compressor replacement is very easy just follow the repair manual,,,get new seals, R134 and a recharge can of PAG150 refrigerent oil.....you will require a vacuum pump after vacuuming the system , then charge the system with the correct amount of refrigerent...
the other option is bypass pulley....no ac but you can get around the compressor pulley issue...
