Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-13-2010, 01:32 PM
70camaro 70camaro is offline
Motor oil in Trans?!?
'96 4cyl. AUTO
I may have inadvertantly put motor oil in the trans when I did a drain and fill. not 100% sure. I thought I had bought trans fluid AND oil, but when I was done only had (full) trans fluid bottles left!
The damn bottles look the same! I think I would have noticed the fluid color not being right, so I think I just didn't buy any motor oil. BUT, IF I DID put oil in the trans, How bad is it? Will drain and fill again if needed.
Thanks in advance.
Old 01-13-2010, 01:39 PM
dab1123 dab1123 is offline
Banned
Re: Motor oil in Trans?!?
First, check the color of the lube on your Trans. dip stick. You should be able to tell by the color. You may have to idle engine for several minutes to allow lube to fully circulate, but best not to drive until you know.
Old 01-13-2010, 01:45 PM
danielsatur danielsatur is offline
Don't forget, the torque converter holds a few quarts!
Old 01-13-2010, 02:09 PM
If the engine was started with the oil mix, all of the oil would be contaminated.
Did you drain both the converter + transmission?
Old 01-15-2010, 12:46 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
DON'T start the car. If you did put oil in, starting it would just circulate it all through the tranny, making cleanout ALOT harder. As suggested, check the dipstick for color...red is good, tan is bad. If bad, you should remove the pan to clean out as much oil as possible. Replace the filter too as it was soaked in oil. You could spray a carb/choke cleaner on the underside of the valve body to dissolve any oil...have the drip pan ready
The TC would not be drained in a regular drain/fill on this engine/transaxle, so it will still have tranny fluid...never seen a drain hole for the TC, though thinking about it there's a strange metal round cover on the outside of the tranny case just held in by clips...a window to the TC? Not even mentioned in the FSM. Or am I confused with my other cars? Have to go check & report back, if it's not too cold to go crawling on cold pavement outside.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-16-2010, 10:18 AM
You can only drain a Torgue converter, after you remove an automatic transmission.
What about a power flush!
