Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '04+
Old 01-13-2010, 01:28 PM
3100 3100 is offline
Banned
jetta 2006 TDI
Hello everyone, I am planing to buy a Jetta 2006 TDI, can someone tell me if this are reliable cars, is there anything that I should look for on this car before I buy it? ei: some weak points, leaks, turbo problems etc. Is there still plenty of life in this engines even if I get one with 80000 or 90000 miles? txs - al
also is there good web site for 2006 TDI engines?
Old 01-13-2010, 02:47 PM
Franco2112 Franco2112 is offline
Re: jetta 2006 TDI
Really fine cars. When buying used with high mileage, vehicle maintenance is the big question! Has this or that been done. For newer small cars the interference engines(timing belt) are prone to fail if not maintenanced properly. Here is most likely the main concern with this vehicle.
Check water pump and timing belt. If in doubt on if it has been replaced get her done together!
About $250 in parts and $500 in labor but well worth it. Here's a link as to what i'm taking about.
http://www.dieselgeek.com/servlet/Detail?no=452
Other than that other issues are minimal.
Try vw vortex for other info.
Franco
Old 01-13-2010, 02:54 PM
mustanger999 mustanger999 is offline
Re: jetta 2006 TDI
All newer VWs commonly have wiring problems. Also if a part goes bad, parts for them run a pretty penny. My recommendation would be to do research on consumerreports.org and weigh the risks for yourself.
Old 01-13-2010, 05:00 PM
Banned
Re: jetta 2006 TDI
gentleman, thank you for fast replies - al
