Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-13-2010, 07:18 AM
a1c little a1c little is offline
Lightbulb 2007 mustang problems
several things i just wanted to ask.
first where can i find windville blue touch up paint for my 07 mustang.
secound why does my car make sqeaking noises under my hood, it stops if i sprey wd40 under there.
3rd my interier has strains on it that just appered from no where, never had spills or leaks, just appered, how do i git rid of them and prevent them, what caused them?
thank you all for your answers....
Old 01-13-2010, 07:31 AM
danielsatur danielsatur is offline
Re: 2007 mustang problems
I like using http://www.expresspaint.com for touch -up, and a Scotchguard spray for car interior.
Old 01-13-2010, 10:12 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Where do you spray the WD-40? By the way WD-40 can be corrosive to some materials so I would shy away from it. Where does the squeaking come from? With the engine cold, remove the serpentine belt and start the car for a few moments. If there is no squeaking you know it is a belt-driven accessory. Do not run for more than 2-3 minutes without the belt or you run the risk of over heating.
With the belt off and engine off, spin the pulleys on the accessories and the idler and tensioner pulleys. See if you can find which one is squeaking.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 01-20-2010, 11:28 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Its an 07 take it to a dealer! Stop spraying wd-40!
Truck lids leak on the mustangs... Squeak is probably a belt or pully... Ford dealer will have touch-up paints. Or Oreillys.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Tags
2007 , interier , mustang , sqeaking , stains
