Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-12-2010, 12:08 PM
regalrobert regalrobert is offline
Service Vehicle, Anti Lock, and Trax lights coming on.
There three lights are coming on simultaneously in my 2000 Regal. Could this be related to a wheel sensor, or is it electronic, and is it anything that can be programmed?
Old 01-12-2010, 03:10 PM
tempfixit tempfixit is offline
Re: Service Vehicle, Anti Lock, and Trax lights coming on.
Check for loose connections or broken wires on the wheel speed sensors first. If all appears fine I would suggest having the ABS scanned with a Capable scanner (Normal scanners for engine codes will not work) to pinpoint the location of problem. You may have a faulty sensor which I believe to replace you will need to replace wheel bearing hub, don't believe you can get sensor seperately. That is why scanning ABS codes will save you some money instead of just throwing parts at it.
good luck
Old 01-12-2010, 03:52 PM
Thanks. Would someone like AAMCO have the proper type of scanner?
Old 01-12-2010, 09:33 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Do they come on after the vehicle starts or after movement?
Timeslip 08/12/06
AF Community Guidelines
Old 01-13-2010, 09:40 AM
When it starts moving. And not every time.
Old 01-13-2010, 06:45 PM
BNaylor's Avatar
The ABS system runs an initialization test in two parts. When the car is started. Checks ABS solenoids, EBTCM module, pump, motorpack assembly, etc. Then once is car is moving it checks all four wheel sensor signals from the hubs. So most likely a defective hub. An ABS scan tool should be able to test it and determine which hub wheel sensor is acting up.
Also, check the wiring and electrical connections at each hub.
Timeslip 08/12/06
Old 01-14-2010, 10:53 AM
When my daughter ran me to work this morning, I noticed that the three light combo came on before shifting into gear. Could I have two different things in play, and will a proper scanner reveal both causes?
Old 01-15-2010, 09:38 PM
BNaylor's Avatar
Normally yes.
Timeslip 08/12/06
Old 01-22-2010, 05:28 PM
Marnav1 Marnav1 is offline
Can anyone direct me to a hub replacement thread? Our Regal does almost exactly the same thing. I did a search and couldn't find one.
Old 01-22-2010, 06:20 PM
BNaylor's Avatar
The procedure is located at Buick Tips & Maintenance forum. See link.
Click here
If you have the original Delco hub and axle nut the axle nut will be 36mm ('97 and up Regal). Good luck!
Timeslip 08/12/06
Old 01-22-2010, 06:35 PM
Thanks!
Old 01-23-2010, 10:11 PM
B. Wilson B. Wilson is offline
I had those three lights coming on before I replaced the ignition switch. It only got worse as time went on. Just a thought!
Old 01-24-2010, 12:41 AM
Ours have come on since replacing the switch. I think it's the left front hub, you can hear a clunk when you take off occasionally too.
