Old 01-12-2010, 10:23 AM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
96 lesabre power is draining?
I have replaced the battery but something else is draining the power from my car. Anyone knows what that can be? A bad relay?
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 01-12-2010, 02:02 PM
tempfixit tempfixit is offline
Re: 96 lesabre power is draining?
You'll need to disconnect negative battery cable and test with voltmeter to see how much of a drain you have. (You will want to wait a few minutes before checking so all the computors and such go to sleep) Then you will need to remove fuses until you find the system with the parasit drain.
good luck
