Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 01-12-2010, 08:15 AM
Bill Wilky Bill Wilky is offline
Adjustment for 2003 headlight
2003 Altima. How can you adjust the driver headlight to bring it downward. Replaced the bulb, but now its upward. Everything seems to be in the proper lined up position. The 2 bubbles on the silver holder are in the slot. Is there a screw to adjust? or do I have the bubbles in the wrong spots?
Old 02-14-2010, 11:56 PM
consultIII consultIII is offline
Re: Adjustment for 2003 headlight
if its out after bulb replacment; make sure the bulb is seated properly.
there is adjustment; with torx driver. screw is accessed from top of lamp assembly.
Old 03-06-2010, 08:42 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
There is a chamfer on the bulb housing, it has to go toward the bottom facing the radiator. Regardless, the 2 bumps have to fit the recess on the housing. I don't think there's any other way to orientate it. How did you do with L-bracket piece with the rectangular slot that goes over it? That was a bugger to install. I taped the bulb to it in 2 spots and used tape to hold the spring clip up out of the way.
My best guess is that the spring clip might not be on right or the L-bracket thing is out of place.
Bob
