Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-10-2003, 10:22 PM
BhSAsiAnBOi BhSAsiAnBOi is offline
Post Help me out?!?
Okay check this out! To all that knows about turbos? Well some guy said that Its bad for IVtec(RSX Type-S) to have turbo. If not then can you send me websites to performace shops that are making turbos for RSX type-S......? Thanks for your time
Old 04-11-2003, 08:41 AM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
The compression's too high, you're gonna blow it!
Old 04-12-2003, 09:23 AM
evo2885's Avatar
evo2885 evo2885 is offline
Send a message via AIM to evo2885
Help me out?!?
try www.cybernationmotorsports.com
PEACE!!!!:smoker2: :grey: :sun: :bandit:
Old 04-14-2003, 02:26 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
lower compression pistons...problem solved. all (well most atleast) honda DOHC VTEC motors have atleast a 10:1 compression ratio, simply have to lower it, an then build ur internals. i don't really think turbo is good for ANY n/a motor, but if u do it rite, then ur motor will still last.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 04-19-2003, 04:30 PM
EncryptedMinds's Avatar
EncryptedMinds EncryptedMinds is offline
If you can add F/I to an S2000 without internal mods then you can Turbocharge an RSX (not to say that it won't go without extra wear on the engine). Rev-Hard has a turbo RSX Type-S among a few others.
www.ultimate-racing.com
So what came first? The chicken or the nuggets?
Old 04-21-2003, 12:22 PM
f1nal zeros f1nal zeros is offline
Send a message via AIM to f1nal zeros
Re: Help me out?!?
Well it all comes down to how much boost you are planning to run.
As you know the RSX type S comes with a very high compression ratio which is 111.
Now turbo can be bad for any motor you have but if you are running a reasonable amount of boost then you should have minimum problems. For all of those who have turbo you all know the maintainence and responsibility of maintaining it. Now there are a few companies who have a turbo for the DC5 which are:
Top Fuel
Greddy
Cybernations
Rev hard
Those are a few companies you may want to look into if you plan to boost.
Well good luck bro.
-Mando
Armando ~ Audra
Old 04-21-2003, 05:19 PM
The number one reason for blowing an engine after adding forced induction is detonation. NOT a good thing. Up to 7 psi seems to be a reasonable amount of boost without running into any major problems. As for me though I'd just add stronger internals for the added insurance against an engine failure.
Old 04-21-2003, 08:23 PM
DOode! Thanks for all the replies! but the thing that question me is how much will I spending on the internals???? Can you send me some good websites to get cheap but good quality aftermarket parts? Thanks again......I think the chicken did man?
Old 04-21-2003, 08:50 PM
You can't really put "cheap" and quality in the same sentence. If you want the best expect to lay a good amount of cash down, but in the end it will all be worth it. Not to say that the most expensive is the best, but you catch my drift.
Old 04-21-2003, 08:54 PM
Yea you can say so DOode! GOod point.....
Old 04-24-2003, 01:24 PM
cheap internals=cheap motor=BOOOOOOOM. if ur going to turbo ur car, do it correctly, and pay the price for high quality parts. if u do it this way, u'll be much safer to run higher boost.
2003 Infiniti G35
