Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 01-12-2010, 07:53 AM
bfd1262 bfd1262 is offline
2003 sonoma 4.3 ltr PO300 code after tune up
I have a 2003 sonoma, I changed the plugs, wires, rotor, and distributer cap and now it runs rough and is throwing a PO300 code. The cap only goes on one way. Any ideas??
Old 01-12-2010, 09:37 PM
old_master's Avatar
Advisor/Moderator
Re: 2003 sonoma 4.3 ltr runs rough
P0300 is almost ALWAYS caused by a fault in secondary ignition parts, (plugs, wires, cap & rotor).
Are you sure the cap is wired correctly?
The 4.3 can be very fussy when it comes to ignition parts. AC Delco plugs #41-993 and AC Delco cap, rotor and wires will assure proper performance.
Low fuel pressure and or excessive leakdown can cause P0300 also. Have you checked fuel pressure and leakdown?
You have to know how it works,
to figure out why it doesn't.
Old 01-18-2010, 06:40 PM
amsman amsman is offline
Did u check gap in plugs? You have the firing order correct?
