Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-10-2003, 10:42 PM
SkyMaxDad SkyMaxDad is offline
How do you test a MAF? Idle problems
I put on a new CAI, now the car will not idle. All hoises are connected, nothing loose or disconnected as far as I can tell.
If I plug up the air line to the IACV it barely idles, if it free flows it wont.
I read that you can test the MAF with a volt meter, what are you looking for? Continuity? Resistance? Diode? What is a normal range etc...
I do not have an engine diagnistic system so I cannot go looking for the P0100 or P0505 codes.
96 Maxima
Thanks in advance
Old 04-11-2003, 09:04 AM
NJMAXSELTD NJMAXSELTD is offline
Your car will idle correctly with a defective MAF sensor.
It will not rev past 2500 RPM's if the MAF is bad.
Conclusion, MAF sensor is not your problem. Go over your install again. Put the stock intake back in, make sure ALL SENSORS are connected. See how the car runs.
While your in there you should clean your throttle body. www.motorvate.ca has a great writeup for that. It takes about 5 minutes to do.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 04-13-2003, 09:01 PM
ShortT ShortT is offline
Send a message via AIM to ShortT
Actually, my MAF was bad and I was able to rev over 2500 rpm's. Sometimes it wouldn't go over 4k but it would stall at idle, and jerk when accelerating. At first I thought it was the knock sensor, I even pulled the code for that. However after I replaced the knock sensor, I still had the same problems. I replaced the MAF and problem was fixed.
