when i start my car..
Sometimes when i start my car i noticed it will almost roll forward an inch or two then kind of bounce back like it does when you first put it in park..I was parked on a slight hill today when it happened. Its not necessarily anything of concern but i was just wondering, it freaked me out once lol.
![]() ![]() ![]() '83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now. -- 65,000 original miles --
Re: when i start my car..
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Probably caused by the drag in the clutch packs taking the slack out of the driveline.
The park pawl should keep the D/S from turning. I'd bet it has to do with the cooling fan clutch, probably stuck engaged... the "propeller" is pulling the car
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
