Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-11-2010, 04:15 PM
bobbys 351 bobbys 351 is offline
no spark
i have a 93 GMC Jimmy it has no spark. I put a new coil,dis-cap button and new ign-pickup in the distributor. still no spark. can someone help me? 4.3 vorteck
Old 01-11-2010, 04:35 PM
danielsatur danielsatur is offline
Re: no spark
The local Auto parts store can do a test on your ignition control module.
Old 01-17-2010, 01:33 PM
Re: no spark
put in new ignition control module. still no spark. and i put in a new brain box.
any input would be helpful.
Old 01-17-2010, 01:59 PM
Re: no spark
What about fuse's, or security system?
Is there a battery getting to the ignition parts?
New parts!
New ignition pickup
New ignition module
If the orginal ignition module was bad, it could of shorted and blown a fuse.
Old 01-17-2010, 02:55 PM
Re: no spark
could a bad fuel pump stop it from firing?
like a safety switch.
Old 01-17-2010, 03:09 PM
Re: no spark
Newer cars might have a safety switch to disable the electric fuel pump when the gas is low, this help to prevent the fuel pump from burning up.
1) Have the local auto parts store test your ignition module.
2) Check the fuse going to the ignition module.
Was the magnetic pickup coil replaced in the distributer?
Old 01-17-2010, 03:18 PM
Re: no spark
yes the magnetic picup is what i put under the dis-cap.
Old 01-17-2010, 08:17 PM
maxwedge maxwedge is offline
A990 racer
Re: no spark
There is no fp shutoff on this truck.
Old 01-17-2010, 09:42 PM
old_master's Avatar
Advisor/Moderator
Re: no spark
The pink wire at the ignition coil must have battery voltage any time the ignition is in the RUN or CRANK position.
The white wire at the ignition coil should pulse while cranking.
Check both pink and white wires at the module connection for the same results.
Post your results.
You have to know how it works,
to figure out why it doesn't.
Old 01-18-2010, 08:27 PM
Re: no spark
got your note. will check it tomoro and let you know.
thanks.
