Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 01-11-2010, 12:40 PM
queen-diva1 queen-diva1 is offline
Unhappy Please Help 1990 Chevy Lumina Apv Smoking Antifreeze problem
I was wondering If anyone could help me? My 1990 APV 3.1 is smoking near the radiator, I cant tell exactly where it is coming from.It is also leaking antifreeze. The radiator is full. The car is not overheating but the reservoir is empty and will not stay filled.
Old 06-22-2010, 11:14 PM
ric_moving ric_moving is offline
Re: Please Help 1990 Chevy Lumina Apv Smoking Antifreeze problem
Bring it to a mechanic asap to check the radiator, and the radiator hoses for leaks. Mechanic can do a compression test of the radiator for leakage. Steam is super hot and dangerous. Bad radiator hose can "bust" spraying super hot antifreeze all over the place causing burn injury.
When the engine is COMPLETELY COLD, feel and examine radiator hoses for damage, leaks, and soft spots. Old radiator hoses should be replaced, even if they are not leaking, as they eventually will in the middle of road. If Bar's Leaks are routinely used in a "good" radiator as a preventive measure, brown spots of Bar's shows leakage points; however, in this case, it is too late for Bar's, as the leakage is fairly severe shooting out steam. Otherwise, green antifreeze spots may or may not show possible leakage points. The mechanics use a pressure pump to find leakages, as they have the tools.
