Old 01-10-2010, 12:43 PM
jjohnson2499 jjohnson2499 is offline
No headlight chime 99 escort se
Any idea where the headlight chime module is? This is at least the second time the headlights have been left on and drained the battery.
Old 01-10-2010, 02:42 PM
Selectron Selectron is offline
Re: No headlight chime 99 escort se
I don't have any info for the '99 but these are the wiring diagrams and module location for the '97 - it says the module is on the rear of the interior fuse panel. The wiring diagram states that the chime will sound when the driver's door is opened, but elsewhere in the manual it states that the chime will sound in response to either front door opening. I would suspect a bad contact in the driver's door courtesy lamp switch rather than a failure at the module, so I'd check out the switch first.
'97 Escort warning chime wiring diagram - part 1
'97 Escort warning chime wiring diagram - part 2
'97 Escort warning chime module location
Old 01-11-2010, 09:10 AM
Davescort97 Davescort97 is offline
Escort guy
Selectron, you are still the best I have ever seen. Keep up the good work.
Old 01-13-2010, 06:43 PM
Intuit Intuit is offline
Seconded Dave.
If it is the doorjam switch, here's what I did for my '94...
http://www.automotiveforums.com/vbul...hlight=doorjam
