Old 01-09-2010, 04:04 PM
devilsadvocate devilsadvocate is offline
1998 Jeep Cherokee limited Gearbox knocking sound
Hi,
I have a 1998 jeep cherokee, at 1300 rpm there is a knocking sound from the gearbox possibly the torque converter. Its an automatic transmission. Could anyone please suggest where the actual problem could be as i don't want to dismantle the whole gearbox without knowing where the problem actually is. Thanx
Old 01-10-2010, 07:39 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1998 Jeep Cherokee limited Gearbox knocking sound
I recall another thread with similar sounds....your torque converter bolts could be loose. If you remove the cover between the engine and trans, that should expose where it's bolted to the flex plate. With the vehicle in neutral and engine off you should be able to rotate to get to them all.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-10-2010, 07:46 AM
Hi, thanx a alot 4 ur advice. I had already checked the bolts and they were all ok. Can there be another problem as this has not solved the issue. Cheers
Old 01-10-2010, 08:06 AM
How many miles and what engine?
Is the sound while you are sitting still, or moving? Does it do it in all gears, in neutral, park, and under what other conditions do you experience the noise?
Tags
cherokee , jeep
