Old 01-08-2010, 09:43 PM
NATIONAL87 NATIONAL87 is offline
2001 s10 wcode 4.3 misfire on 3 cyl..spider or reg?
I have a 2001 4.3 vortec doing the exact same thing..runs great when first started..then 5-8 miles down road it runs rough under 2k basically..sets a check engine light & show to have misfire on three same bank cylinders..do you think this may be the fuel regulator or still possibly the spider?
W code 4.3 2001 model..replaced cap,rotor & fuel pump..
Thanks for any help..
Old 01-08-2010, 09:58 PM
danielsatur danielsatur is offline
Re: 2001 s10 wcode 4.3 misfire on 3 cyl..spider or reg?
Bad Air, or fuel problems can cause random misfire.
Air - filter, maf, iact, dirty throttle body, or unmetered air leaks on EGR, PCV, and intake.
Fuel - filter, pump , fuel regulator, injectors
Exhaust - Catalytic converters, mufflers, tail
I have seen a plugged cat choke half an engine out, causing random misfires.
Broken pieces of a cat can plug the down stream exhaust.
Did you read http://www.automotiveforums.com/vbul...d.php?t=324122
Bad intakes gaskets & seals will cause unmetered Air leaks,
Old 01-09-2010, 10:22 AM
j cAT j cAT is offline
Re: 4.3 vortec misses on 3 cyl
Originally Posted by NATIONAL87 View Post
I know this is a very very old thread but I have a 2001 4.3 vortec doing the exact same thing..runs great when first started..then 5-8 miles down road it runs rough under 2k basically..sets a check engine light & show to have misfire on three same bank cylinders..do you think this may be the fuel regulator or still possibly the spider?
you need to check the fuel pressure..it must be 60-66 psi..key on engine running...with the key off the fuel pressure should hold steady and fall only a few psi in 10minutes...
if it falls off rapidly this may mean the fuel regulator/metering, injector , fuel pump....
to replace the regulator you must remove the upper intake manifold.
after that I would check for vacuum leaks PCV system etc...
Tags
misfires , random
