Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-08-2010, 05:28 PM
12field 12field is offline
Ford Explorer 2003 no start - engine rotates
I have spark - not sure about fuel but sprayed starting fluiding into intake and did not get any firing. Oil and coolant looks good so do not think headgasket is problem. Vehicle shut off once and restarted, got it home but cannot get it to fire again. Any ideas would be greatly appreciated! Thanks!
Old 01-08-2010, 05:29 PM
danielsatur danielsatur is offline
Re: Ford Explorer 2003 no start - engine rotates
Symptoms of a bad or dirty maf
Old 01-08-2010, 05:31 PM
Hard cold start is a symptom of a bad, or dirty MAF sensor.
The air is metered, it sends a cold start signal to the PCU/ECU.
Old 01-08-2010, 05:35 PM
Wouldn't I get some firing from the starting fluid? Thanks for reply.
Old 01-08-2010, 05:58 PM
The Air/fuel mix is set by the ECU/PCU during the cold start conditon, the fuel pulse is long + starting fluid = flood!
The MAF sensor is a metering device for air, a cold start signal is like telling the ECU/PCU that you need a choking condition for a cold start.
If not a bad MAF sensor, it could be unmetered air leaks.
Old 01-08-2010, 07:56 PM
Davescort97 Davescort97 is offline
Escort guy
A dirty MAF sensor will cause an overly rich mixture upon trying to start. Get some electronics cleaner spray and clean the MAF wire inside the housing. If you want you could pull a plug and see if it is wet with gas. If this occurs it is a good indicator that the MAF is dirty. btw. If you unplug the MAF sensor it will send a rich mixture to the computer by default.
Old 01-08-2010, 08:01 PM
The PCV system will actually contaminate both sensors.
Old 01-08-2010, 08:34 PM
rhandwor rhandwor is offline
Are you getting any indication of a security problem. These will cause no starts.
Old 01-08-2010, 09:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
And don't rule out a bad crankshaft position sensor. These have been known to cause issues on the earlier Explorers. I'm not so sure if they were still common issues on the 2003 and newer model.
Which engine is in your Explorer?
-Rod
Old 01-09-2010, 09:19 PM
-Rod
THanks for all the good ideas. Today, I cleaned the MAF, confirmed spark and fuel into cylinder and still no firing. Would a bad crakshaft sensor prevent spark as I have it? Any other ideas out there would be great. THANKS!
Old 01-09-2010, 09:20 PM
I will check on this tomorrow. THANKS!
Old 01-09-2010, 09:21 PM
I will replace it as cheap. Would this prevent firing as I appear to have both fuel and spark.
Old 01-10-2010, 01:37 AM
Escort guy
More than likely it is the CKP sensor sending spark at the wrong time.
Old 01-11-2010, 07:40 PM
We replaced the cam positioner sensor but no luck. The MAF was only cleaned and not replaced but did not seem to matter- plugs were wetted but not fouled so should have got a fire out of it. A ticking type noise seems to be coming from front end of engine. Security is not the problem - no lights anyway. Any other ideas would be appreciated. Thanks
