Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 01-08-2010, 04:31 PM
Kevcules Kevcules is offline
2006 Corolla with engine light on
How can I retrieve my trouble codes for my car? What type of code reader is necessary for my car? The vehicle has 87000 km's on it and works OK other than low idle at cold start and rough idle occasionally.
Thanks
Kevin
Old 01-08-2010, 05:25 PM
danielsatur danielsatur is offline
Re: 2006 Corolla with engine light on
Any local Auto parts store should beable to pull your codes for free.
Do a Google P-code!
''Corolla P0XXX''
Old 01-09-2010, 09:13 PM
Thanks... I'll try that.
Old 01-14-2010, 02:43 PM
I retrieved my trouble code... "P2716" I believe it's called "pressure control solenoid" Where is it and can I repair it?
btw..In Canada they all charge for reading codes ...
Kevin
Old 01-14-2010, 02:49 PM
Hanes + chilton will not work for new cars, see www.alldata.com
Doe's this car still have any type of warranty?
Emission laws in the US are good for 7-years!
Do a google ''P2716 Toyota''
You might be covered for 8-years, or 80K miles, check ASAP.
Old 01-14-2010, 06:30 PM
Yeah...I just found out Haynes doesn't make a manual for it.
It's an 06 with 87000 km's , I'll check into warranty...
I did google the trouble code number and it came up with "pressure control solenoid" and ECM problems. That wouldn't be related to emissions right?
Old 01-14-2010, 09:03 PM
roadrunner2 roadrunner2 is offline
The pressure control solenoid is in the transmission.
The problem with doing nothing is not knowing when you're finished.
Old 01-22-2010, 06:51 PM
It seems the problem is quite common. The "ECU" is defective and is replaced if you have less than 100,000 km's on the powertrain warranty.The service manager said he didn't recognize the code but then told the service rep to help me out with "that rough shifting problem" they are seeing???
Kevin
Old 03-30-2010, 09:29 PM
leiyuan leiyuan is offline
depends on toyota TSB, need replace PCM, your car still under powertrain warranty, check your local dealer
Old 04-27-2010, 05:57 PM
The dealership did end up replacing my ecm for nothing,covered under warranty.
Kevin
