Old 01-08-2010, 03:18 PM
numbpain numbpain is offline
Amp RCA jacks
Hi,
Did my first install and ran into some trouble when my amp wouldn't power on. Went back and looked over everything and there are a couple of things im not sure about:1. Which wire exactly does the remote wire hook up to? I Had it connected to a wire that says "amp ground", is that right or should it connect to another blue wire that says "antenna power"? 2. the instructions on the amp kit said to connect the RCA jacks to the left and right audio on the head unit, and i did. However, i have a lot of RCA plugs on the head unit and only ONE says " SUB RCA".What do I do?
thanks
Old 01-09-2010, 07:52 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Amp RCA jacks
standard HU wiring:
Yellow - goes to a const 12V source
red - goes to a switched 12V source (only comes on when the key is on)
black - goes to ground
blue - raise antenna when RADIO (not CD) is turned on
blu w/white stripe - amp rem, turns on amp when headunit is on
on the amp:
pwr - goes straight to battery (remember to use a fuse close to the battery)
gnd - goes to a pl;ace on the chassis close to the amp. remeber to crape away all the paint and dirt
rem - the blue/white wire from the headunit connects to here
RCA's - if this is a bass amp, it will go to the RCA's on the back of the headunit that says sub. Remember that you might have to turn on the sub output on the HU.
Old 01-11-2010, 01:26 AM
Re: Amp RCA jacks
Originally Posted by PaulD View Post
standard HU wiring:
on the amp:
OK, so in my case the RCA's connect to those that says sub on the HU. However, I only have one RCA on the HU that says sub. Which from the amp do I connect, blue or gray or is something not right?
Old 01-11-2010, 05:45 PM
Audio Guy
Re: Amp RCA jacks
read the amp manual, it should tell you if you only need one input. It's odd you only have one SUB rca, you should have a pair. What headunit and what amp ?
Old 01-16-2010, 05:09 PM
Re: Amp RCA jacks
its a dp 311x, 3in screen HU and a crunch pzi 4175 1000w max amp
Old 01-17-2010, 08:44 PM
Audio Guy
Re: Amp RCA jacks
ok, that's a 4 channel amp so I now I don't know what you are trying to do.
