Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 01-08-2010, 02:43 PM
danford1 danford1 is offline
1998 E350 with V10 start and cold run problems.
I have a 98 E350 with a V10. 120,000 miles (brief history - the plugs were changed about 1000 miles ago along with coil packs).
I only drive the van once a month or so. It sits more than it should, I know...
Recently, it is hard to start. It used to fire right up, idle and drive fine. Now it takes a few seconds of cranking before it spit and sputters then dies. I have to repeat this 2 or 3 times until it will run and idle smooth. It will bog and sometimes die if given Any gas. It acts like an old carburetor with a bad accelerator pump. I know it doesn't have a carb just acts like one...
Once it runs for 5 or 10 minutes and is warmed up, it drives fine with no bog.
What can I look for?
Danford1
Old 01-08-2010, 08:29 PM
rhandwor rhandwor is offline
Re: 1998 E350 with V10 start and cold run problems.
http://www.fordfuelinjection.com/?p=28
Check your ohms based on morning outside temperature.
