Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-08-2010, 02:28 PM
taxidermist taxidermist is offline
95 camry rear brake line size
I have to replace my brake lines along the frame and was wondering what size the line is and what size is the bolt? I would think it is metric but not sure. With the rust on them I want to be sure and use the right wrench the first time.
Thank you,
Rob
Old 01-08-2010, 02:48 PM
nmikmik nmikmik is offline
Re: 95 camry rear brake line size
I assume you meant the nut not he bolt, not sure of the size of the lines most are 1/4 - here is some info on how to make sure:
http://store.fedhillusa.com/technica...wtopdfs.aspx#2
Nuts on the proportioning valve are 10mm, assuming you are going all the length. But if yours are rusted really bad I doubt you are going to be able to turn them even with the flarenut wrench.
2014 Camry LE Hybrid - 19000 mi
2014 Chevy Spark EV - 5000 mi
2014 Chevy Spark EV - 3500 mi
2002 Lexus LS 430 - 105000 mi
2001 Volvo S40 1.9 T - 140000 mi
Old 01-08-2010, 04:25 PM
Yep I ment nut not bolt, I am going from the valve back to each wheel. Due to to nice dirt,salt,snow catching guard they put on them it has rusted thru.
Thank you,
Rob
