Old 01-08-2010, 03:02 AM
flashlight flashlight is offline
Frost on the Inside
Got off from work and went to scrape the windows like normal. After scraping the outside discovered that the inside also had frost buildup on it. What could have caused this to happen? And is there a way to fix it so that it doesn't happen again? Thanks for everyone's help in this matter.
Old 01-08-2010, 04:28 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: Frost on the Inside
You got into the car with snow all over your boots and when it melted it made the inside of the car humid. When you stopped driving, the windows fogged up, then froze. Open a window a crack or, even better, get into the habit of leaving your HVAC set to bring in outside air.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 01-08-2010, 04:51 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
yes, the frozen windows also happens if the car is left outside in the sun. A sunny winter.s day turns the car into a little greenhouse. It warms up enough to make it nice and humid inside. As the sun goes down, the car cools off, the humidity condences on the windows and freezes.
As noted above, park with a window open a crack, especially on a sunny day.
Old 01-09-2010, 12:37 AM
brivers brivers is offline
Your heater core is leaking.
Old 01-09-2010, 04:33 AM
Woodie83's Avatar
That's a very real possibility that I had overlooked. If the heater is leaking you should smell it though.
Woodie
Old 01-09-2010, 09:50 AM
It is a very small leak that exhumes a mist you can't see,.... yet.
Old 01-09-2010, 10:33 AM
MagicRat's Avatar
Uh..... no. Respectfully, this is impossible.
Leaking heater cores leak antifreeze, which does not turn to frost on the window. That is why it's called antifreeze The only way this would be possible is if the cooling system had only water in it...... which would have frozen by this time, and would have broken the engine block.
The antifreeeze residue would remain an greasy, liquid layer on the window and would have a distinctive odor, as noted above.
Old 01-09-2010, 12:05 PM
You sound awfully sure of yourself Magic not knowing what his antifreeze protection is degree wise, or outside temperature is. Under most circumstances, moisture inside the car means heater core leak.
Impossible.....I think not. Respectfully that is.
Old 01-09-2010, 01:16 PM
Leaving the window open just a crack before going to work and there was no frost on the inside this time. Also there is no strange smells that could be coming from the heater.
Old 01-09-2010, 04:21 PM
MagicRat's Avatar
No... it's impossible. What you say is impossible, due to simple physics and the parameters of the post. Here's why:
1. If its cold enough to freeze coolant on a parked car's windshield, its cold enough to freeze the coolant in the engine block, radiator and heater core.
2. When these components freeze solid, they rupture, because the frozen water or coolant expands (by about 10%). This rupture is enough to cause a major coolant leak, the next time the engine is started.
3. Now, since the OP is still driving the car and mentions nothing about a massive coolant leak, nor a coolant odor, we can assume no parts have ruptured.
4. This means that its not cold enough to freeze the coolant.
5. Therefore, any leaking coolant will not freeze on the windshield.
6. Therefore the ice on the windshield is not coolant.
Understand?
Now, forgive me if I seem cranky, but if this still does not make sense to you, please enlighten yourself to the basic laws of thermodyamics.
http://en.wikipedia.org/wiki/Laws_of_thermodynamics
Old 01-09-2010, 04:26 PM
danielsatur danielsatur is offline
Was the external circulate (fresh air) vent open all night? Almost like leaving a window open all night.
Old 01-09-2010, 07:38 PM
consultIII consultIII is offline
caused by environmental conditions/humidity like some of the others have posted. I've found cleaning the inside of my windshield reduces it somewhat. I think I remember from science 101, 22 years ago, that up in the clouds snow crystals first form around dust in the atmosphere.
Old 01-09-2010, 07:51 PM
[quote=MagicRat;6090368]
Don't want to get into a thing with you Mr. Einstein.
I never said it was antifreeze that froze on the windshield. I simply was offering a possible problem he could have. A leaking heater core can humidify the air going through it which can condense on the inside of the windshield and freeze or fog on the glass. Hell, it could be snow melted on the floor humidifying the air, I don't know. Maybe its not his heater core, but if it were my car I would be concerned and at least check it. I didn't see where you posted a possible cause to his problem, only criticisms of other posts.
Old 01-10-2010, 04:41 AM
Woodie83's Avatar
Leaking heater core will absolutely fog up the windows, why wouldn't it freeze? Engine coolant is 50/50 antifreeze and water, soak the carpet really good and the water is going to evaporate out of it.
Woodie
Old 01-10-2010, 09:25 AM
randall 37382 randall 37382 is offline
Just thought i would throw this out there. If by chance you had a hole rusted in the floor, you could be getting moisture in your carpet from there. Might cause the greenhouse effect. Just a thought.
