Old 01-07-2010, 06:35 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
low coolant light when cold
recently my low coolant light has been going on when i first start the car and the engine is cold. after it warms up the light goes off and sometimes goes on and off while warm intermittantly. i added more coolant and there appears to be plenty in the resevoir... any ideas?
Old 01-07-2010, 06:37 PM
danielsatur danielsatur is offline
Re: low coolant light when cold
A bad, or contaminated coolant level sensor.
Old 01-07-2010, 06:48 PM
TDWPgtp's Avatar
where is it located and how can i check...
and might it have anything to do with the hose that should be attached to the cap fell into the resevoir?
Old 01-07-2010, 07:03 PM
Sorry! my http://www.alldata.com expired.
Old 01-07-2010, 07:28 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Sensor is gummed up or bad. What year is your car?
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 01-07-2010, 07:56 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Mine did this once too about 2 weeks ago. No clue why. It was -15 with -30 windchill and car started just fine without being plugged in, but the low coolant light came on. About 5 miles down the road when the car was warm the light shut off and I havn't see in since. The design of the low coolant sensor on these car's isn't the greatest. I was having a lot of issues with it for a while.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-07-2010, 08:14 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
yeah, these coolant sensors are real flaky. horrible design IMO
Old 01-07-2010, 08:16 PM
TDWPgtp's Avatar
97. where is the the sensor and can it be cleaned? or does it have to be replaced
Old 01-07-2010, 08:25 PM
the sensor is located towards the bottom of the coolandt reservoir. in the '97 it can be a little tougher since its in a $hitty spot. you'll need to remove the brace to get the reservoir out if I'm remembering right.
you can try cleaning it first. i got sick of replacing mine so i just disconnected it.
Old 01-07-2010, 09:37 PM
tblake's Avatar
In God We Trust
I thought they were located on the passenger side of the radiator, about half way down.
I was having an issue with mine, I removed it, cleand it good, and put it back in along with replacing the radiator cap. Its been good since except for that once staying on when its really cold.
Old 01-07-2010, 10:11 PM
you might be right Tim, I'll have to double check. i know on some cars its in the radiator not far under the radiator cap, and some it is in the reservoir
Old 01-07-2010, 10:14 PM
The sensor on the radiator is for the coolant electric fan, the Temp sensor on engine is for the temp guage.
Old 01-08-2010, 12:10 AM
doctorhrdware doctorhrdware is offline
Getting a little cold up there Tblake. It is still above zero down here.
Old 01-08-2010, 11:07 PM
tblake's Avatar
In God We Trust
yep, -5 on the HVAC in the GTP on my way home from work and its actually the warmest night in a week.
Old 01-12-2010, 10:22 AM
TDWPgtp's Avatar
the tube attached to the resevoir cap fell into the resevoir and i cant seem to get it out... is this a big deal?
