Old 01-07-2010, 02:51 PM
99silve 99silve is offline
4wd problem help
ok heres my problem hope u can help... this summer my 4wd went out, found the atc fuse blown replaced that then the service 4wd light came on after that replaced switch, motor, and actuator. without taking it to a dealership what else could it be. 99 silverado 4wd 1500 5.3L short cab
Old 01-07-2010, 04:09 PM
j cAT j cAT is offline
Re: 4wd problem help
when fuses blow check wires for damage rodent etc..including the under hood fuse block under fuses..
Old 01-07-2010, 04:51 PM
J-Ri's Avatar
J-Ri J-Ri is offline
You'll need to check codes if you don't find a chewed through wire. The fuse didn't blow the second time and the light is still on, correct?
A cheap code reader won't do it (usually), you need something like a Tech-2 or MODIS for 4wd codes. Sometimes you need to take it to a shop, at least for diagnostics. I know people like to do it themselves and save money, but guessing at parts rarely accomplishes that.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-15-2010, 11:42 PM
bromelandb bromelandb is offline
i have a similar problem on my '01. went to put it into 4hi and the indicator light just went out. wont come back on and the 4x4 doesnt work. once the service 4x4 light came on briefly. maybe the 2 problems are related?
Old 01-18-2010, 05:52 AM
Blue Bowtie's Avatar
Registered Offender
Originally Posted by bromelandb View Post
i have a similar problem on my '01 ...maybe the 2 problems are related?
Nope. Yours is on an '01, and the other is on a '99. Couple that with the fact that your vehicles are on opposite sides of the Mississippi, and that just about removes any chance of the problems being related.
That said, I'd suggest getting the truck on a lift or solid jack stands, then having an assistant engage the TC ranges while observing the actuator at the case. See if the front and/or rear shafts even attempt to move or lock in the various ranges. You can usually hear the TC actuator motor running.
