What kind of differential?
I tried to search this but all I could find was drum to disc brake conversions, and not what a 94 Caprice normally came with.
I had a blow out on my rear left tire the other day, and bought a single replacement tire, which will arrive sometime next week. I literally couldn't afford a second tire, just didn't have the money cause the stupid rims on it require tires that cost 150 each. I was told to put it in the front, and put the front tires in the rear to not burn up the differential. But I thought the 94 caprices had an open differential, which means the rear left tire is just "limp" like the fronts, does nothing.. I can't find anything about them.. I did a lookup on my car and this is the options it had.. Vehicle: CAPRICE CLASSIC 4 DR Year: 1994 Build Date: 1993-12-08 Found 96,919 vehicles matching your year and model in our database. RPO Description Matches UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6) 57,893 UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 91,365 UQ5 SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE QUARTER MOUNTED 4 SPKR SYS(UQ5) 64,594 U02 CLUSTER,INSTRUMENT,KILOMETER AND MILES,DIGITAL DISPLAY DIGITAL DISPLAY CSTR(U02) 65,157 U73 ANTENNA,FIXED FIXED ANT(U73) 60,045 V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 86,007 Z09 CAPRICE CLASSIC(MERCHANDISING OPTION)(1BL19 & Z09 = 1BN19) CAPRICE CLASSIC(Z09) CAPRICE CLASSIC(MERCHANDISING OPTION)(1BL19 & Z09 = 1BN19) CAPRICE CLASSIC(Z09) CAPRICE CLASSIC(MERCHANDISING OPTION)(1BL19 & Z09 = 1BN19) CAPRICE CLASSIC(Z09) 32,054 1AY Unk. 32,029 1SE PACKAGE OPTION 05 (1SE) 7,027 16Q MOLDING COLOR,BRIGHT WHITE (16Q) 28,809 16U EXTERIOR COLOR,PRIMARY (16U) PRIMARY COLOR EXT,PEARL WHITE (16U) 32,496 41P WHEEL COLOR,BLACK (41P) 23,690 6TF COMPONENT-COMPUTER SELECTED SUSPENSION SUSP(6TF) 19,616 64I INTERIOR TRIM,LIGHT BEIGE (64I) 14,314 642 TRIM COMBINATION LEATHER, LT BEIGE (642) 2,472 7TH COMPONET-COMPUTER SELECTED SUSPENSION SUSP(7TH) 19,616 74A ACCENT STRIPE,LT CHESTNUT (74A) 23,063 8RZ COMPONENT RR LH - COMPUTER SEL SUSP (8RZ) SUSP(8RZ) 27,795 9RZ COMPONENT RR RH - COMPUTER SEL SUSP (9RZ) SUSP(9RZ) 19,118 AA7 WINDOW,ELECTRIC OPERATED,QUICK OPENING QUICK OPG ELEC WDO(AA7) 88,588 AG1 ADJUSTER,SEAT,6-WAY POWER,DRIVER(60-40)(VAR 2) 6-WAY PWR D/SEAT ADJR(AG1) 53,921 AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5) 96,919 AM6 SEAT,FRONT SPLIT,3 PASSENGER WITH CENTER ARMREST FRT SPLIT ST(AM6) 59,226 AP9 NET,CONVENIENCE CONVENIENCE NET(AP9) 34,057 ARL PLANT CODE-ARLINGTON TX, CPC ARLINGTON,TX ASSEMBLY PLANT(ARL) 96,919 AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 93,498 A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 61,609 BV2 ORNAMENTATION,EXTERIOR,REAR COMPARTMENT LID MOLDING RR COMPT LID ORNAMENTATION(BV2) ORNAMENTATION,EXTERIOR,REAR COMPARTMENT LID(EXPORT) RR COMPT LID ORNAMENTATION(BV2)(EXPORT) 32,035 BV8 ORNAMENTATION,EXTERIOR,DOOR HANDLE(DELUXE) PAINTED DR LK CYL(BV8) 32,054 B18 ORNAMENTATION,INTERIOR(DELUXE) DELUXE INTR(B18) 25,799 B92 ORNAMENTATION,EXTERIOR,FRONT FENDER NAME F/FDR N/PLT(B92) 19,275 C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 88,804 C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 96,919 C71 LAMP,INTERIOR,FRONT DOOR COURTESY FRT DR CTSY LP(C71) 32,054 C96 LAMP,INTERIOR,QUARTER COURTESY AND SINGLE READING QUARTER CTSY & RDG LP(C96) 48,284 DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4) 24,047 DD2 MIRROR,INSIDE,SUNSHADE,COVERED I/S CVR S/S MIR(DD2) 32,054 DL8 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG ELEC R/CON HTD O/S MIR(DL8) 31,799 D64 MIRROR,INSIDE,RH VISOR VANITY,ILLUMINATED ILLUM S/S MIR(D64) 45,888 D90 STRIPE,FRONT END AND BODY SIDE(PAINTED) PAINTED BODY SI & F/END STRPE(D90) 27,798 FE1 SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1) 27,795 FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9) 77,693 GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2) 39,578 IQ2 TRIM,INTERIOR DESIGN (IQ2) 11,897 JA1 BRAKE SYSTEM,LIGHT WEIGHT,DISC,DRUM LGT WT BRK SYS(JA1) 38,851 JM4 BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON) ANTILOCK DISC/DRUM BRK(JM4) 58,854 K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 67,410 K68 GENERATOR,105 AMPERE 105 AMP(K68) 36,879 L99 ENGINE GAS, 8 CYL, 4.3L, MFI 4.3W(L99) 52,793 MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0) TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0) 96,919 M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30) 96,919 NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 88,713 N30 STEERING WHEEL(DELUXE) DELUXE STRG WHL(N30) STEERING WHEEL(DELUXE)(EXPORT) DELUXE STRG WHL(N30)(EXPORT) 77,215 N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40) 96,919 N65 WHEEL AND TIRE,SPACE SAVER SPARE(STEEL) STEEL SPACE SAVER SPA(N65) 23,391 PA5 CAP,HUB(SPORT) SPORT WHL HUBCAP(PA5) CAP,HUB(SPORT)(USED WITH AL WHL PD4) SPORT WHL HUBCAP(PA5) CAP,HUB(SPORT)(USED WITH AL WHL PD4) SPORT WHL HUBCAP(PA5) CAP,HUB(SPORT)(USED WITH AL WHL PD4) SPORT WHL HUBCAP(PA5) 23,691 PB4 LOCK KIT,ALUMINUM WHEEL AL WHL LOCK KIT(PB4) LOCK KIT,ALUMINUM WHEEL(EXPORT) AL WHL LOCK KIT(PB4)(EXPORT) 29,990 PD4 WHEEL-15 X 7 LIGHT METAL ALLOY, 5 SPOKE 5 SPOKE AL WHL(PD4) 23,691 QCV TIRE ALL P215/75R15/N WS2 R/PE ST TL ALS TIRE(QCV) 25,920 R6A Unk. 18,929 R7A Unk. 80,917 R7R Unk. 30,356 R8S Unk. 9,317 R8T Unk. 18,870 TL1 GRILLE,SPECIAL SPECIAL GRL(TL1) 25,732 T87 LAMP,CORNERING COR LP(T87) 31,972 -- 0 Rarity... There are 1 1994 CAPRICE CLASSIC 4 DR vehicles (0.001%) matching your exact options list. There are 2 (0.002%) with at least as many options. The rarity of your vehicle is based on an exact match of your options for your year and model.
![]() My one and only car! 1994 Chevy Caprice Classic LS L99 Engine |
Re: What kind of differential?
Do you have speed rated tires you were trying to match?
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip, 1989 Mustang LX 5.0 5sp convertible 1992 Camry LE 2.2 1996 Suzuki RMX250 I'm a victim of circumstance [ |
Incase you didn't notice in my signature that the rims are custom, the rims that came with the car when i bought it take 255 50 17
![]() 17" tires are more $$ for sure. The price you pay for hi performance. As long as they are the same size, I don't see how they would hurt the Diff.
Those specs are what the car left with from the factory.
The differential is the same, it was never changed, but I need to know what kind of differential I have.. New tire, different BRAND, same size, no wear vs 3 other tires of different brand with wear. I forsee a differential that's gonna go through hell.. I could put the new tire up front, but then i see it messing with the steering.
To confirm, you could jack up the rear of the car and turn the wheels. If both turn in the same direction, you have a posi, if not, it is an open diff.
to check this out jack up one rear wheel if limited slip it should be hard to rotate hence the limited not locking diff...slippage does occur with these limited slip diff's supplied to some of these vehicles... most have the open diff unless when built it was ordered with this option which should be listed in the glove box... also on the rear axle housing passengerside facing front there should be letters/numbers identifing this axle.. upon looking at your list of as built equiptment you have the 2.73 ratio diff..this is not limited slip...this is a very reliable open diff used for decades by GM.. however I would put the new tire on the rt frt of vehicle... I also noticed how they installed the fe1 springs now that is a very poor spring ! did you ever change the springs ? I got bf goodrich 255 50 z17 tires from costco for about 120 installed..these only last 35,ooomi very soft rubber .. |
never touched the springs.. don't know if any previous owner did though..
