Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 01-07-2010, 11:09 AM
Mr.Fred House Mr.Fred House is offline
Talking 2004 Tiburon wont START
Before I get started I would like to say that I went through ALL 43 pages of TIBURON forums to see if anyone else hade the same problems as me so I would not duplicate and make anyone MAD.
I have a v6 auto Tiburon that died while driving. I checked with a test light to the plug wires and no power. I unpluged the coil harness wires and getting power to the harness wires, but no power to the plug wires from the coil itself. I checked for codes and nothing their. The check engine light comes on when you turn on the ignition, so the ECM is getting power. Checked ALL fuses-good. The compression is good, The only thing I can think of is the CRANKSHAFT sensor. How do I test this and Am I doing proper testing to diagnoses this problem. I have not changed any parts out yet...
Old 05-23-2010, 10:49 PM
promo123 promo123 is offline
Re: 2004 Tiburon wont START
how about READING the CEL...did that idea ever strike you as a good one?
Old 05-24-2010, 12:09 PM
ricebike ricebike is offline
i'm with promo... why are you just testing a random sensor when you didn't hook up an obd II scanner and see what the code is? don't guess it's the crank sensor- that should set off a code if the wiring was cut or the sensor went blah...
edit: re-read your post... look below for a possible cause
Old 06-07-2010, 06:47 PM
chev100 chev100 is offline
Did you get the Tibby fixed. My daughter is having a similar problem, car quits while driving and won't restart. Let the car sit 15 minutes and it does restart. no codes.
Old 06-07-2010, 07:54 PM
my bad... you said you already checked for codes...
i've heard if there's a crack on the ignition coil pack, it can exhibit this problem
http://www.hyundaiforum.com/forum/sh...ad.php?p=25835
i'm guessing when warm, that crack creates increased resistance...
you can do an ohm test with the coil to see if there's continuity, but it won't check if it's good; that check will only confirms it's bad.
