Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 01-06-2010, 09:07 PM
Tig2312 Tig2312 is offline
Question 1998 Honda CRV AC High Pressure
AC stopped blowing cold. Thought a recharge might solve problem. Got a do it yourself kit . Pressure on low side was at 150. Is there a some type of regulator valve in the system? Any helpful hints to fix? Thanks
Old 01-07-2010, 06:55 PM
DownToGround DownToGround is offline
Re: 1998 Honda CRV AC High Pressure
sounds like you need to have a shop recover the old refrigerant in the system, and have it recharged.
Old 01-07-2010, 08:19 PM
Thanks Down Ground. Pressure on the Low side should be around 30. You think a recovery of the system and recharge will solve problem? Thanks
Old 01-08-2010, 11:26 AM
there is a schrader valve to release the the pressure, how ever illegal..sounds like a recharge would fix it, short of the pump not doing its job..good luck
