Old 01-06-2010, 08:57 PM
gserve gserve is offline
rear window defog
How do you test a rear window defogger? There is 14.5 volts at the terminals when the button is pressed. There is no broken grids. HELP!
Old 01-06-2010, 09:04 PM
danielsatur danielsatur is offline
Re: rear window defog
Wait until the morng, see if it works!
Isolate the grid by disconnect at rear window, and measure the resistance of the grid.
Old 01-06-2010, 09:35 PM
What is the resistance supposed to be? I have already repaired one tab and it worked for a few days.
Old 01-06-2010, 10:07 PM
How many amp fuse is assigned for the rear defroster?
12volts / ? = little
R=E/I
Old 01-06-2010, 10:21 PM
It has a 30 amp fuse to it. I also have heated mirrors on the same circuit as the defogger. The heated mirrors work.
Old 01-07-2010, 06:05 PM
Here's a good fix, see http://www.popularmechanics.com/auto...o/4221212.html
Old 01-07-2010, 09:22 PM
old_master's Avatar
Advisor/Moderator
If you show battery voltage at both terminals on the glass, there is no ground being supplied. Check the ground wire connection at both ends of the wire.
Old 01-07-2010, 09:44 PM
old master, Are you saying that I shouldn't have 12 volts when putting my tester at both terminals when the switch is on? Wouldn't one wire be + and one be - and you get 12 volts when the switch is turned on? Please clarify. Thanks
Old 01-07-2010, 09:54 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Measuring across the grid, you should have battery voltage.
I, and presumably he, thought you meant that with the ground probe on ground you measured voltage on both sides.
Sounds like the rest of the circuit is good then, so the problem has to be with the grid. I'd double check the terminal you repaired. Not sure on the resistance, I'd expect up to 10 ohms... definitely not "OL"
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-07-2010, 10:05 PM
old_master's Avatar
Advisor/Moderator
J-Ri Exactly.
With the ground probe of the DVOM connected to chassis ground: If both terminals of the grid show battery voltage, that means the grid is good but not getting a ground.
Old 01-07-2010, 10:17 PM
Hey!
I found some videos, see http://www.youtube.com search ''Auto rear defrost repair''
Old 01-22-2010, 10:45 AM
91goldbomb's Avatar
91goldbomb 91goldbomb is offline
simalar to the headlight problem i had on our cavalier the sockets have constant power but when the switch is turned on it completes the ground kinda reverse to what youd nomally think youd think theres constant ground and switch completes the + circut not sure why they did it this way or if theres any reason behind it but def check all your grounds and make sure they are all clean and tight and no breaks inbetween
Old 01-22-2010, 01:14 PM
old_master's Avatar
Advisor/Moderator
Originally Posted by 91goldbomb View Post
.... not sure why they did it this way or if theres any reason behind it
Ground side switching is used in certain circuits to reduce or eliminate corrosion.
You have to know how it works,
to figure out why it doesn't.
Old 01-23-2010, 10:26 AM
91goldbomb's Avatar
ah i see interesting well it sounds like agood idea but not sure it works 100% as in our cavys case it did not but who knows prolly just got one of them cars that needs the constant attention
