Old 01-06-2010, 03:49 PM
Dannny b.'s Avatar
Dannny b. Dannny b. is offline
stripping paint
Hi guys
the thing is simple, I F%$#&* up the paint on my tamiya supra, there are just too many wrong things with it. Is there a way to strip the whole paint and primer from the body and start from the beginning?
cheers
Dan
Old 01-06-2010, 04:42 PM
koksik's Avatar
koksik koksik is offline
Re: stripping paint
Brake fluid or the best choice is Isopropyl alcohol
Old 01-06-2010, 04:44 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: stripping paint
Also oven cleaner works good.
In Progress
Old 01-06-2010, 05:17 PM
stevenoble's Avatar
Re: stripping paint
Depends on the paint..?? Enamels=Oven Cleaner, anything else=Isopropyl Alcohol...
Steve Noble
Old 01-06-2010, 05:39 PM
koksik's Avatar
Re: stripping paint
All paints = brale fluid
Old 01-06-2010, 05:56 PM
tuned.by.twenty's Avatar
tuned.by.twenty tuned.by.twenty is offline
AF Vendor-TBT's Owner
Re: stripping paint
Brake fluid is a simple and effective choice. Let the body sit, and when after a while you should be able to get all the paint off by running over it with a toothbrush or something similar. Be sure to rinse it after though.
Old 01-06-2010, 06:08 PM
stevenoble's Avatar
Re: stripping paint
My opinion of brake fluid is that it will strip the paint but it is not the best option. Cheap it may be, but the couple of times I used it it took ages to strip the paint and made the plastic weak and brittle. Also stripped a red body shell and the colour bled out of the plastic, turning the primer pink when I re-primed. Isopropyl alcohol is much better in my opinion. No brittle plastic and a nice, easy and clean strip. Only thing it smells very strong, other than that it's fine.
Steve Noble
Old 01-06-2010, 07:16 PM
MidMazar's Avatar
Re: stripping paint
Also if you put it in a container filled with alcohol to sit for a few days, remember to put the cap or top on the container. If not the alcohol will evaporate pretty quickly.
In Progress
Old 01-06-2010, 11:18 PM
carbonkid carbonkid is offline
Re: stripping paint
I use super clean it works great
Old 01-07-2010, 03:11 AM
Dannny b.'s Avatar
Re: stripping paint
Thanks guys!
u have been very helpful.
will go the local paint shop and will try the isopropyl alcohol.
Old 01-07-2010, 03:15 AM
Dannny b.'s Avatar
Re: stripping paint
Thanks guys!
Its a laquer paint, will see what works better..will try the alcohol first.
Old 01-07-2010, 03:18 AM
Dannny b.'s Avatar
Re: stripping paint
Thanks guys!
Old 01-07-2010, 04:32 AM
gtziaf's Avatar
gtziaf gtziaf is offline
Re: stripping paint
Very useful advices here...
A similar question. How to strip paint of a burrago 's metal body (my 456 or polistil's mondial)? Is the isopropyl alcohol the solution?
Thanks..
Old 01-07-2010, 05:40 AM
stevenoble's Avatar
Re: stripping paint
Thanks..
If you have the metal body minus all the plastic parts just use regular paint stripper available at all diy stores. It will strip it clean off in minutes. Just don't use it on plastic kits or you will end up with a molten blob of plastic...
Steve Noble
Old 01-07-2010, 05:41 AM
stevenoble's Avatar
Re: stripping paint
Originally Posted by Dannny b. View Post
Thanks guys!
Make sure you get the Isopropyl Alcohol in 91% or higher concentration. It will say so on the side of the container..
Steve Noble
