Old 01-06-2010, 10:47 AM
ss#4 ss#4 is offline
99 Silverado 4 wheel engagement
I have a crazy problem with the 4 wheel drive. Initally it would not enage at all replaced the dash switch and now it will switch in an our to auto, 2w, 4h and 4lo, but it wil only do it if the key is cycled. So if I start the truck in 2w it will not switch unless the truck is shut off and then 4h is selected. Has anyone had any similiar issues???? What was the fix? No codes at this point.
Old 01-06-2010, 11:44 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 99 Silverado 4 wheel engagement
What transfer case?
How Have you checked for codes?
Will it switch from 4W to 2W without key off thing?
MT
Old 01-06-2010, 01:50 PM
not sure on the t-case number. just a 1/2 ton ext cab 99 silv
There are no codes
No it will not switch with out key off/on routine
Old 01-06-2010, 03:37 PM
MT-2500's Avatar
AF - Advisor
How and with what did you check for codes?
Does the 4W buttons have a auto 4W button.
The transfer case ID is on back of transfer case.
MT
Old 01-06-2010, 03:43 PM
snap on scanner
yes it has auto, 4hi, 2hi and 4 lo. I will check the tag on the case.
Old 01-06-2010, 04:07 PM
MT-2500's Avatar
AF - Advisor
If the snap on scanner is transfer case/transmission capable it should set a code if a problem.
Just OBD11 scanner will not get into transfer case stuff.
Did you read out all shift data and go threw the shift test built into scanner.
MT
Old 01-06-2010, 05:24 PM
j cAT j cAT is offline
I would guess its the transfercase encoder motor...
with the drive train oem specific codes I can get you in the correct direction..
Old 01-06-2010, 05:57 PM
okay I will rescan and see if anything has come back up.
