Old 01-06-2010, 08:36 AM
jtc001 jtc001 is offline
02 T&C Power Steering Resevoir replacement
I own an 02 Chrysler T&C van with the 3.8l. The power steering resevoir needs to be replaced. The only way I see to loosen the bottom bolt is to remove the large hose, the hose that goes to the PS pump.
I can not determine what is the best way to drain that hose without getting PS fluid all over the engine. Any ideas?
Thank you
Old 01-09-2010, 06:43 PM
hundahunta hundahunta is offline
Re: 02 T&C Power Steering Resevoir replacement
you can use a old turkey baster and remove as much fluid as possible prior to removal..
