Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 01-05-2010, 06:35 PM
dawnnewsome3 dawnnewsome3 is offline
97 cirrus loses power above 3500 rpm
Hello, My Cirrus 2.4L loses power above 3500rpm, starts and idles fine but seems to die when you try to get on it. No codes, 135,000 miles, new head gasket cause it was leaking oil down the back of the block and now it blowed a exhaust gasket. I think the catalytic converter is stopped up cause it is also rattling. Thought a get some opinions before I tear it out. thanks for any advice.
Old 01-18-2010, 10:22 AM
tradeinc2222 tradeinc2222 is offline
Re: 97 cirrus loses power above 3500 rpm
Hello,
I have a Chrysler Stratus 1997 model , i remove the brain box to start another Chrysler of my type , my brain box started the car , by the time i return it to my car ,it started it but the engine off after every 1 mins.
Kindly advice what can i do to it
REGARDS
James
Old 01-23-2010, 02:17 PM
Hello, Try removing it and make sure all the connections are clean if it worked before it should work again.
Old 01-25-2010, 08:34 PM
Well it was a bad Cat, finally put it on a lift and low and behold a big dent in it. Cut it off to replace and it was busted in half inside and the insides was turned sideways blocking flow. Should have figured it was something like this the wife already knocked a hole in the oil pan. Should never have gave it to her after I lowered it. Women without them we would not have cars to work on.
